best vista skin mod for xp
Caporegime
1 Jun 2006
Notts
well would like to mod xp to look like xp whats best free pack to do this and easiest way to do it with least errors , faults. also if it does go wrong/dont like is it easy to put it back to normal xp themes and stuff thanks any links would be helpful.
I had one prevent XP from booting. I was able to fix with system restore though. I did get it working in the end but it slowed down XP booting. Been using Vista for about 9 months now, so its been a while.
xpize simply patches the bitmaps in file (so is safe)
brico packs actually replace the files (could be old or conflicting file versions on your pc then) -unless they've changed it recently..
