Sanding down the IHS to make it flat. better temperatures
Is it possible if you sand it down too much then your going to sand away something important to the cpu? Never lapped or even bought pc parts, apart from a gfx card , so i wouldnt know!
What sorta temp differences would you notice by lapping the CPU ?
Not really. You start with 400grit paper and work your way up to 1200 depending if you want the shiny look or not.
ok i am going to go out and buy some sandpaper (of which i know nothing about really) do i buy 400, 800, and 1200 only? do i need to be in between as well?
well, to be honest the xp vs vista debate isn't showing anything here. xp default install is fairly memory/process heavy compared to a nice clean multiple process disabled install. likewise vista can be streamlined for performance massively, much further than xp. for instance getting into xp is one thing, getting into vista and loading up all the cache into mem means its simply doing a lot more work. disable superfetch, and a bunch of other stuff and you'd have a different story.
once you hit max stable speed there shouldn't be any difference between either OS.
hello
well just testing atm...at 4ghz with 1.4v....temps i cant tell as mobo temps only go as low as 1c
but probs around -25-30c
going for around 4.5ghz but i think maybe that would need 1.7v...cpuz reads it a fair bit lower than in bois atm
hello
What mobo?
What phase?
Has to be a heck of a unit with those temps. Getting -25c with a dual at 1.65v, and I'm not even sure the mount is right.
