Ah, i thought it was back then!Yes, it was a while back.
Post 23 actually.
Some planes do, personal ones in jumbo jets would never be viable. Look how long it takes to get everyone on and off the plane...
Can't a massive parachute be put onto the back of the plane for such emergencies?![]()
I really wanna see someone try the elevator "jump before you land" thing, I'm refusing to believe it doesn't work until I see someone try it![]()
i'm sure a system could be possible if they tried.
Planes can glide. They can't glide well, largely because they are far too heavy, but they can glide. A skilled pilot might be able to make a plane lose altitude slowly enough for a landing to be survivable, in some circumstances. I've read that a pilot once brought a 747 down safely when it suffered total engine failure over the Alps, managing to reach a runway that had been cleared for the emergency and making a rough but adequate landing with no injuries to the passengers or crew.Exactly what im thinking, the plans goin down for whatever reason, (dont understand why they cant glide persay) and open it high enough where the air is thin and wouldnt break the shoot, and yeh float down, no doubt it would be a mother of a wack and break some things but better than total incineration. lol
One of things pilots practise on a regular basis, is a total engine failure and finding a suitable landing site as close as possible. Basically the cost of ejection systems isn't viable for commerical aircraft. Military aircraft have a variety of systems.
http://www.ejectionsite.com/eairliner.htm
http://www.ejectionsite.com/b58capsule.htm
http://www.f-111.net/ejection.htm
http://www.ejectionsite.com/f111restore.htm
http://en.wikipedia.org/wiki/Escape_crew_capsule
Basically flying commerically at least is very safe. Your more likely to die from something else.
Possible injuries to passengers due to use
It takes 78 seconds to evacute a fully laden A380(873 people). Quite quick if you ask me. Course it's still pointless
