Bored? Flash Game: MuseLock!
17 Jun 2005
London
http://20six.fr/muselock
You've been knocked unconscious and wake up in a room full of objects to help you break out. Be warned - there's traps all over the place so think twice before you pick things up. I got stuck halfway so had to Google for some help but completed the rest of it on my own.
The site's in French but you can play the game in English too.
I did the same :)
I now have a box, a key, some paper, a can and have seen some shapes on the wall.
[edit]Ooooooh, the room has gone red
Try using the paper and can behind the projector. ;)
That's the part I had to Google. No idea how you're supposed to guess it on your own.
I figured it out on my own. When you click above the fuseboard with the can, it tells you to use something to guide the liquid, or something similar. Took me a while to work out it was referring to the paper though. But now I am stuck, keep getting gassed. :(
