As for the poster above, Denon isn't high-end, they're budget gear.
And if it's bi-amped, then why only a single cable to the speaker? Should have two runs.
so it can't be...just a marketing term. Only a single amp is driving the left & right, and the sub by a third power amplifier.
yeh, sorry if i've been arrogant.
But i just cant believe that those tiny, puny looking denon speakers cost £2000, even though they're technically "crapper" than my £300 system!
Anyway, I guess i'll have to hear hear it to believe it.
No need to waste money on that stuff. Cheap 'van damme' blue speaker cable is much better value at around £1.50 a metre and you won't be able to tell the difference between the two. You can buy custom lengths over at AVforums.com from some guy.
But ye, we need to let him go and demo a few systems. I really recommend NAD !
My point being you've got some toysRus stereo that looks like it belongs in the bedroom of a furiously masturbating spectacled boy in an arsnal vest. !
HAHAHAmy point is not that the example i quoted is the best speaker cable around, just that the stuff that is used to attach those speakers is absolute crap and here is a rough comparison, and the rule of thumb i go with is that 10% of your budget should go on interconnects and speaker cable no point in 400 quids worth of kit and cables such as those in the dude spiccy to connect them up...
Whilst the Denon systems typically discussed are budget level kit, that's not to say that Denon doesn't produce high end gear.
Go run a google search on the Denon PMA-SA1. From what I can see, that costs a cool £5499, which does strike me as probably being fairly high end. Having never heard it, I'm not going to comment on it's abilities, but chances are that it's not rubbish.
Bass response? You havn't heard a thing yet!
Was just thinking the same here. Amplification wise i've only got the smartpower and a psx-r so i'm pushing a sweet 60 watts @ 8ohms.I wonder what you'd think of my tiny Cyrus setup![]()
id stick with your current system looks smart to me
I had a sony one of them about 10 years ago and that was wicked loud![]()
Theres two cables coming from the speaker, the blue one and the red one, each had a + and - cable
This information means that only one signal is entering each speaker. This means therefore that there are passive crossovers within the speaker housing (the signal is split into high/low/mid frequencies after amplification, not before...).
