Hi all,
Well after a disastrous attempt to upgrade from a SN21G5 to a SN26P I've decided to see what the cost is to replace most of the Shuttle
Basically I have -
SN21G5
2 x 1Gb PC3200
Athlon X2 4200+
Sapphire X1950 Pro
WD 250Gb Sata2 Hdd
NEC DL Dvd Writer
And I was going to swap the base out and replace the X1950 Pro with a 8800GTS
This meant spending around £400 on replacement parts.
Can anyone spec me something of around the same value if I lose the X2 and PC3200? Or is it not viable?
I really do prefer Shuttles hence posting in the SSF section
Thanks,
Whoop
Basically I have -
SN21G5
2 x 1Gb PC3200
Athlon X2 4200+
Sapphire X1950 Pro
WD 250Gb Sata2 Hdd
NEC DL Dvd Writer
Thanks,
Whoop
