are they Z10's viper ? been looking at them and the 2.1 versions, how bassy does the bass come through them ?
There is a 2.1 version of the Z10's?
If you like lots of bass dont get the Z10's.
well kindaits the Z2300 i was on about, i like the look of the Z10's but when i go from gaming to my music , i got quite a bit of music which is bassy
oh well
Here's my room, in my new uni flat
like those shelves, where did you get them?
Thanks
The Z10's are practically bassless compared to a 2.1 system, but considering their size, they can throw out a bit of bass...
But as said above, if you want bass, do not get these.
Hey bud, I like what you've done to your case, with the rad inside at the top etc. Looks awesome!
I have the same case, and was woundering.. with the rad in there at the top, can you still stick PCI cards in? like a new soundcard or somthing? Is there much room for that kind'a thing?
Thanksi![]()
Thanksi![]()
I have the same case with a Black Ice 360 mounted in the roof and it blocks PCI slots, providing you have 3 or more you can still install cards etc, but the BI GTS i have is 28mm thick so thats probally why![]()
Yeah, mine is 60mm thick, and then there is 25mm of fan above that...
Just got to finish of my lan pc, and then im migrating this one into a new case, either a v2000b, or an mm UFO, either way, it'll still be internal water cooling, and will definately have to go for 2 loops![]()
Is that the 22" Daewoo screen?
Here's mine (again):
what speakers and amp you running raikiri ?![]()
