If that's real, then I note the single additional power supply connector, and not the 2 previously used.
Matthew
now tats a more reasonable sized cooler. and is tghat a single 8 pin or 6 pin power connector?
some rumours say it'll be faster and some say it'll be as fast as the r600What's the rumoured speed on these anyway? 2900XT speed? Slower? Faster?
i think the connecter is only used when the card is used in a pcie 1.x slot...If its using PCI-E 2.0 it can draw 150W from the connector, so could still need loads of juice. Not sure if this does use 2.0 though.
well don't get your hopes up on that.With it being 55nm there should be a lot of overclocking potential to come out of it.![]()
