but it does seem that it doesn't really bring that much to the table
(Apart from a potential lower price according to Fudzilla - not a good source)
) then it would be worth waiting for it to come out I suppose. What do you guys think?but as i said before even if it can be clock to 900+ on the core it doesn't mean it'll go faster, the fps may stay the same or even drop.. the 2400/2600 is 65mm but they are very different to overclock.. e.g past 857mhz theres no different even if u clock it to 891 or to 901, the fps just stays the same or slows down not speeds up..What is interesting about that though is the gigaflop value. Based on a quick and dirty calculation:-
R600 @ 742Mhz = 474 GFs
R670 @ 825Mhz = 528 GFs
but... R600 @ 825Mhz = 527 GFs
The give with one hand (more mhz, die reduction) and the other hand they taketh away (memory bandwidth down to 256bit from 512bit)
So basically all they are doing getting better yields, higher frequency from this and claiming better performance due to the mhz. I'm not complaining as it may mean potential to easily reach 900Mhz on the core (575 gigaflops)but it does seem that it doesn't really bring that much to the table
If it is truly gonna be around $249 (£150 as it's always marked up) then it would be worth waiting for it to come out I suppose. What do you guys think?
Matthew
i know the r600 as no problem overclocking.. but im just saying don't get your hopes up to high about the rv670 overclocking mate... we'll only know when it's releasedWhat about current R600's then? Does the extra Mhz actually increase performance at 900Mhz compared to 825Mhz? (for those crazy enough to do that on water?)
Matthew
lol buy r600 pro now for 800-850Mhz , or 670 later with possibility of 850-900mhz lol. the new Dilema... and less heat / noise / elec bill hehe.
Matthew
2900xt,pro, gt is EOL at the end of october..EDIT: Think about it for a few seconds more... it will pretty much have to cost more than the current XT anyway, unless they do a price cut, which I can't really see them doing. Is this the reason for the pro's? trying to get rid of r600 cores so they can release the R670? Although, no one has mentioned End of Life for the 2900xt as yet?!?
Matthew
AMD plans to launch Radeon HD 2900 GT on October 8th at US$199 while HD 2900 Pro continues to be in limited supply at US$249. The existence of these 2 cards are just to get rid of the R600 stock that didn't attained XT speeds before RV670 comes along in November. However, HD 2900 XT, GT and Pro will reach EOL by end of October so the lifespan of the two new cards is really short. Radeon HD 2900GT will sport only 240 stream processors instead of 320 and a 256-bit memory interface instead of 512-bit for the 2900 Pro. HD 2900 GT card uses 256MB of GDDR3 memories while 2900 Pro card is able to use 512MB to 1GB of GDDR3/4 memories. Both cards are clocked at 600MHz core and 1.6GHz for the memories.
asus m2r32-mvp motherboard as the 580x ( x16/x16 crossfire) north bridge which is pcie 1.0a...Why would you replace the motherboard? Far as I can tell they are backwards compatible with pci-e 1.1. I have more to worry about as I'm only on 4x pci-e eek (asrock 4coredual).
Matthew
Hi , how do you all think the HD2950 XT/Pro will compare to the current Nvidia 8 series , only i am getting a x38 chipset board and was wondering about crossfire again , last used ati cards and crossfire with two 1800xt's and since been with Nvidia.
i can overclock my 2600xt's to 904mhz but don't see any increase in performance... and i know it clocked it because the temps go higher, (56 ida, 65 load)
the 2600 haven't got voltage controls. i think it does it by itself..Gareth. If it's your GPU you are not seeing the performances from then I'd suspect a limit of 857Mhz for your core on stock voltages. I got to these kind of stages where raising my core and passing 3dmark06 flawlessly would result in a lower score. My default core voltage is 1.150V and raising it to 1.213V started to raise my score at the higher GPU clock. There were 4 increments between 1.150v and 1.213v and I tried every one of them so my GPU was definitely held back by volts.
Install ATI Tool 0.27 b2 and then start raising voltages a little. Find out what your exact stock volts should be for your card and then raise Core, MEM or Memory outbuffer voltages as required. (Tip. I found raising the memory buffer(MVDDQ) volts to help me get higher memory clocks better than raising memory(MVDDC) volts.
