final spec check before order
12 Sep 2005
Norwich, England
hey well here goes. i shall be adding a sata hd but not decided which 1 yet.
let me know if everything will be compatible and i havnt forgotten anything or owt.
cheers
o yer, is that psu gonna b plenty good enuf for the spec?
will probly add a pce-e soundcard at xmas and a 1tb hd. will it be able to handle those additions easy?
If you plan on clocking change the ram, i've heard its not that good for clocking but really really solid at stock.
Look at some ballistix for OCin :)
he'll get a gd oc with the ram at stock anyway. most 2x2gb kits arn't good clockers, but he probly wants to keep some slots free.
lol i was 1 click away from ordering then.
right. im not into hardcore overclockin but wudnt mind a bit. will what i've chose b ok 4 that.
what *** you suggest?
if you don't care about having free ram slots, then just get 4x1gb it's cheaper and better for oc'ing.
I'd say get the ocuk 8800gtx aswell personally.
I know this opens up the whole "2 sticks Vs 4 sticks" thing but £170 seems a lot to spend on memory when: OCZ 2GB (2 x 1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) is £44.64 (x2 ?)
ocuk version is 1800mhz compared with 2000mhz and warrenty is better, thats whats kinda sways me. thing is though, ram i chose is fast at stock right? what sort of overclocking am i gonna hav 2 do 2 get another type up to and obove what i chose, will it be hard?
