VGA cable + the lack of turning on the extended color options maybe? a longshot is suppose.
Could be I guess, not sure though it was a direct feed not a cam job or anything. (Direct feed would be recording directly from the game right?)
Should be under the display settings in the setup tab of the dashboard, helps with the washed out issues.What's this "extended colour" options you speak of? Just got a 360 and using it over VGA, and the colours do seem a little washed out.
The main disadvantage of the 360 version from what I've heard is lag and reduced player capacity for each map/game.
is there going to be any games arranging through here?
