- 19 Dec 2003
Ah cool, if you were a beginner was going to recommend some stuff to you, but you wont need it![]()
Ah thanks anyway
You in the industry then?
I'd recommend more ram, like the dude before said. I get lags with 8GB ram! My spec is basically the same bar gfx card (8800gtx) and ram (8gb ocz) and vista x64; handles max very nicely. Rendering with mental ray with 4 cores is a dream![]()
cool cool, dont think i can afford 8gb though
Ah thanks anyway
