D-Tek FuZion Nozzle Kit
13 Nov 2003
Cumbria
Just noticed they are available in the Uk now, has anyone ordered any yet?
I'm hoping the Royal mail will have them here before Saturday.:)
I've been looking at them on pre-order but I want to see if they actually do anything with the Quads before spending the fiver.
It's not the money (honest!), it's the bother of fitting it.
The 4.5mm nozzle is meant to be very very good for the dual-cores.
I've just noticed the block needs to be stripped to fit the "O" ring, and the quad nozzle is a split one.
For £5/cpu it has to be worth a punt, although none of my stuff is actually running over 60C at the moment, so I'd only be doing it for the e-penis extension.
I fitted the quad nozzle, and "O" ring this morning. They seem to work for me.
Q6600 (G0) 3.6 1.41 Vcore
Pre Fitting. all cores maxed out for 1 hour, small fft's, and readings from Coretemp.
61 60 57 57
After fitting, and allowing the machine to warm up alittle. Again 1 hr of small fft's
58 56 52 51
I might try the 3.5 nozzle next.
Had my nozzle kit on order for a month receive it on Monday, and i intend to lap the hamster cpu (B3). Will post results.
Used arctic silver temps 48,42,43,42 changed over and used liquid pro 40,32,32,32 cooled on an arctic pro 7 couldn't over clock though like a BBQ.
Servo is your cpu lapped?
