13 Oct 2007 at 10:48 #1 Conrad11 Conrad11 Soldato Joined 12 Jun 2005 Posts 5,361 Hi there, I am wondering if Vista with all the fancies on is going to affect my gaming performance. I use Aero i think? <-- how do i know i am using it? I also use the Windows Sidebar as well. Just wondering what you thought? Thanks.
13 Oct 2007 at 15:59 #2 modo77 modo77 Soldato Joined 31 Aug 2004 Posts 3,658 Location Sol System Aero turns itself off when you start a game
13 Oct 2007 at 16:00 #3 Conrad11 Conrad11 Soldato OP Joined 12 Jun 2005 Posts 5,361 Ok kool. Weird question, but what exactly is aero? I know of it and that its a theme, but i don't actually know what it is and what it does?
13 Oct 2007 at 16:33 #4 bledd bledd Don Joined 21 Oct 2002 Posts 46,837 Location Parts Unknown disable windows defender real-time scanning, will speed gaming + the pc up and don't use av
13 Oct 2007 at 16:49 #5 modo77 modo77 Soldato Joined 31 Aug 2004 Posts 3,658 Location Sol System Its the glass effect on the windows, and the 3d flipping thing
13 Oct 2007 at 16:50 #6 waso_dude waso_dude Soldato Joined 22 Oct 2006 Posts 5,913 how do you use the 3d flipping thing?
13 Oct 2007 at 16:51 #7 modo77 modo77 Soldato Joined 31 Aug 2004 Posts 3,658 Location Sol System Windows key and tab
13 Oct 2007 at 16:54 #8 Conrad11 Conrad11 Soldato OP Joined 12 Jun 2005 Posts 5,361 bledd. said: disable windows defender real-time scanning, will speed gaming + the pc up and don't use av Click to expand... Already found that tip you gave in another thread. It's a work PC aswell so i need an Antivirus, I am using NOD32 RC atm.
13 Oct 2007 at 16:54 #9 bledd bledd Don Joined 21 Oct 2002 Posts 46,837 Location Parts Unknown ctrl + windows key + tab makes it stick (dont need to hold keys then) but it's a pretty useless feature, i've only used flip once, and that wasn't in the last month of heavy use that this pc has had
