Field Value
CPU Properties
CPU Type DualCore AMD Athlon 64 X2, 3000 MHz (15 x 200) 6000+
CPU Alias Windsor
CPU Stepping JH-F3
Instruction Set x86, x86-64, MMX, 3DNow!, SSE, SSE2, SSE3
Original Clock 3000 MHz
Min / Max CPU Multiplier 4x / 15x
Engineering Sample No
L1 Code Cache 64 KB per core (Parity)
L1 Data Cache 64 KB per core (ECC)
L2 Cache 1 MB per core (On-Die, ECC, Full-Speed)
Multi CPU
Motherboard ID TEMPLATE
CPU #1 AMD Athlon(tm) 64 X2 Dual Core Processor 6000+, 3006 MHz
CPU #2 AMD Athlon(tm) 64 X2 Dual Core Processor 6000+, 3006 MHz
CPU Physical Info
Package Type 940 Pin uOPGA
Package Size 4.00 cm x 4.00 cm
Transistors 227.4 million
Process Technology 9Mi, 90 nm, CMOS, Cu, DSL SOI
Die Size 230 mm2
Core Voltage 1.100 - 1.450 V
I/O Voltage 1.2 V + 2.5 V
CPU Utilization
CPU #1 / Core #1 6 %
CPU #1 / Core #2 20 %
Field Value
Sensor Properties
Sensor Type ITE IT8716F (ISA E80h)
GPU Sensor Type Diode (ATI-Diode)
Chassis Intrusion Detected Yes
Temperatures
Motherboard 40 °C (104 °F)
CPU #1 / Core #1 37 °C (99 °F)
CPU #1 / Core #2 36 °C (97 °F)
Aux 46 °C (115 °F)
GPU1: GPU Diode 58 °C (136 °F)
GPU2: GPU Diode 55 °C (131 °F)
Hitachi HDS722512VLSA80 34 °C (93 °F)
Hitachi HDS722516VLSA80 32 °C (90 °F)
Maxtor 6V160E0 37 °C (99 °F)
WDC WD2500KS-00MJB0 39 °C (102 °F)
WDC WD3200AAKS-00SBA0 34 °C (93 °F)
Cooling Fans
CPU 2961 RPM
Chassis 1870 RPM
Power Supply 1418 RPM
Voltage Values
CPU Core 1.40 V
+2.5 V 2.99 V
+3.3 V 3.23 V
+5 V Standby 5.13 V
VBAT Battery 3.25 V
