Update!
Right, I told you all that I ran out of batteries yeserday, so I went down to do some work this afternoon, and took some pics..
Here's how it was as of last night...
So anyway, I pulled out my now defunct Hiper Type-R PSU and took it with me to test fit in the PSU port this afternoon
Fits like a glove :thumb: (I'm relieved becuase I was basing the hole distances on an internet diagram :worried
Space is quite tight, but I've quadrouple measured everything and there is enough room for sure in there..
(i'll also be using a slightly bigger PSU)
with the motherboard tray in.. It attaches to the front and rear panels with 8 20mm tabs
(4 on each side)
and finally, showing the dimensions..
And last, but not least in the slightest, I need to thank some sponsors!
Firstly,
Willie from
HWLabs For hooking meup with a special edition Black Ice GT-Stealth 240 radiator. Thanks a lot! :thumb::thumb::thumb:
And
Mario from
Feser 1 for organising a package full of green water-cooling goodness! Thanks indeed! :rock::thumb:
