Project: Watery
Update!
I came back to my room from half-term to see some lovely packages...
The First one is full of lovely Feser stuff! sponsored by Mario from The Feser Shop!
Some UV Green String for cables ect.
A couple of meters of 1/2" Acid Green UV tubing
1/2" Barbs and tubing clips
Acid Green UV Non-Conductive Feser! :rock:
Another Update in a mo!
Sponsors!
Willie from HWLabs
And Mario from Feser 1
Update!
My other package!
Full of lovely AC Ryan bits!
Did someone say RadGrillz?
In Black? Yep! These are aluminium as opposed to stainless steel for the silver ones. These should polish up a treat!
10cm and 20cm UV CCFl's. As you know, 30cm's won't fit due to the small dimensions!
3x120mm ACRyan Blue LED fans...
A whole bunch of UV green sleeving and molex's ect.
And some quick mocups! More tommorrow!
There were also bunches of SATA cables, but I seem to have lost the photos of them!
Sponsors!
Willie from HWLabs
Should have called it toxic waste, with all that Green glowing kit inside!
Not to my taste, but really enjoying this thread, keep up the good work, and thoses updates.
Thanks :D
Update 5! Fans and Grills!
So today, i started by drilling the holes to a larger diameter on my Rad Grillz. I went to 5mm for the mounting holes, and 4mm for the the fan mounts..
I laser cut the holes for the fan and the grill, aswell as some for a Bulgin switch and USB's, FireWire and audio sockets, but I somewhat mucked them up :sigh: But thats not too bad... I'll redo all the panels when the entire project has been done so that they are imaculate...:dremel:
When its dark, there is a cool glow through the rad... Also, these fans move a lot of air, and are a little to loud for my liking... The are 'quiet' but not silent.. So, i think i'm gonna have to buy/make a rehostat :dremel:
nice design mate
looks the perfect size for a cubed case
only thing is its going to be tough hiding the wires unless you decide to braid them
5-stared
I'm not so sure about the grills, especially the radiator one where its inside the case. To me they somehow don't fit in with the shiny clear bling theme of the case. But thats just me and I've no idea what I'd use instead!
Other than that its looking great, keep it up!
PK!
PK!
They still need to be chromed is all!
