Does a diesel need a CAT to pass an MOT?
PAz
PAz
18 Oct 2002
Beds
Hi
As title really, I've read that a diesel doesn't need a cat to pass an MOT...can anybody confirm this is true? Some googling suggests yes but just want to clarify ;)
Can't decide whether to go for a full system with decat or just a straight through after the cat...
Ta
Hi
Ta
Doesn't need one. My 1995 diesel Golf certainly went through without one, CO2 wasn't even tested.
No it doesn't need one, and it's not a CAT, its a particle filter
As long as the smoke levels don't exceed the test spec it will pass, nothing else is tested on a diesel.
Most modern diesels will have a Cat as they reduce NOx emissions. Some very modern diesels have particle filters which trap and burn off particles but these will do nothing to reduce NOx.
A Peugeot 306 HDi will have a cat, it certainly won't have a particle filter - the first car fitted with a particle filter was the PSA 2.2 HDi engine fitted to the 406 and the C5.
Diesels require a cat to meet emissions regualtions, but this is not (currently) tested during an MOT. Diesels are subject to a smoke opacity test which only measures the opacity of the smoke coming from the exhaust.
