Crossfire 2600xt on an RDX200?
10 Dec 2004
Oxfordshire
looking at the perfrormance potential of 2 of these cards in crossfire. i have 2 Crossfire bridges ready and waiting.
Would 2 of these run on my current 380w Enermax PSU?? i have a single x1950gt 512mb clocked and running fine on it
and most importantly, will the mobo do it, and is the upgrade worth it, in reviews i have seen 2x2600xt's getting 8.5-9k in 3dm 06 where my 1950 is scraping 5k
any thoughts on the pro's cons etc are welcome :)
ta
Ben
For the price of 2 x 2600XT you could practically buy 1 x 2900Pro which would be a FAR FAR better purchace.
you wanting a boost for just now? why not just get a second GT?
Anyways I would say if you are going for a more powerful card(S) best to stay on the single card basis as it always works out fine and crossfire, sli can sometimes take some time to be implemented in games :)
i have 2 2600xt which cost me around £150, but they are cheaper now. as for 3dmarks i get :
3DMark Score 9551 3DMarks
SM 2.0 Score 3696 Marks
SM 3.0 Score 4650 Marks
CPU Score 2584 Marks
the big question is what does your pci-e's run at in crossfire mode? if its x16/x4 or x8/x8, u won't get the full benefits out of the cards, x16/x8 isn't to bad but x16/x16 is much better
unless its an X38 board they run at 16x and 4x
the AMD 480X CrossFire Chipset runs at x8/x8.
the AMD 570X CrossFire Chipset runs at x16/x8.
the AMD 580X CrossFire Chipset runs at x16/x16.
thanks for all the replies guys, was considering a 2nd x1950GT, but that would mean a PSU upgrade and i thought maybe i could have got away with using my old one with 2 2600xt's
Think im just gonna wait until the 8800GT comes out and then start thinking about a bigger jump :)
kinda off topic, sorry, but 2 x8 slots will not limit those cards in any way shape or form. a GTX is only slightly limited at those x8 speeds.
x16 and x8, or even 2 x8, will be much more than enough for 2 x2600xt's
The 2900pro or the new 8800 are the only way to be looking rather than buying 2 lower spec cards outright.
Edit: What about getting another gb of mem? Would smoothen the framerates in the newer games. :)
well my gf old system ran at x16/x4 then i changed her motherboard to a x8 /x8 and both was slower than my x16/x16.... now shes got a dell system...
out of curiousity, would a 380w PSU run 2 of the 2600's in crossfire? im guessing that they dont require a power feed outside of the mobo?
well for my system (specs in sig), at ida its about 340W and load 385W.. so u should be ok...
no it doesn't need extra power...
