Do the HD2900's still have the AA resolve issue? or did they figure that one out?
Would it not be cheaper to buy a SLi motherboard and another GTX?
I mean if 2x2900 Pro = roughly £350 you'd be better off with SLi GTX's surely, they are faster in SLi are they not?
Make sure you purchase some ear plugs aswell
Game performance you'd stand no chance![]()
In call of juraze the cross fire achualy did worse then a single card.
The GTX is a powerful card and if you are thinking of switching you might as well just get another gtx and a new mobo as if you have a P35 mobo you only get a 4x lane. Crossfire on a 4x lane with 2 overclocked 2900 pros i dont think will beat gtx. Specialy on games with not particulary good crossfire settings. Plus you dont get 1gb of memory if you have two 512mbs. You only get 512mb therefore the 756 on the gtx is more usefull.
A CrossFire tandem made out of two ATI Radeon HD 2900 XT cards is quite a different thing. Costing about $800-1000, which is comparable to the price of a GeForce 8800 Ultra, this configuration outperforms the Nvidia solution across a number of applications. Our testing has shown that ATI CrossFire technology enjoys a solid support in Windows Vista, obviously due to the high-quality Catalyst driver for the new OS.
That paragraph is taken right out of the conclusion from the above review. So basically a crossfire solution is faster than 1 ultra and there for faster than 1 gtx.
Right just thought, if you buy into crossfire ain't you looking at like £400 when including the price of a motherboard and 2 of the 2900's?
Would get better performance by getting one of the sub £100 SLi boards and a GTX for £300, plus less power usage and heat.![]()
