- 18 Oct 2002
- England
Got my P182 the other day.... pretty gutted with it had my perfectionist views so I guess wasnt gonna be pleased.
My P182 review (warning some people will hate me afterwards!)
I tried the panels and sound dampening or 3 layer shielding which doesnt do anything.... no difference to fan noise much to warrant a mention no where on same level as NX hushes noise dampening!
Found it very tedious to work inside, just no space simply put, the size to work with is the same size as the full size ATX mainboard...
I could fit my entire arm in my old Eclipse 62 that was with it all built !
Took me an entire day to manage the cables/keep it clean and just about managed to squash the cables on the right hand side panel again just too small to work comfortably and speedy with.
The mid bay Ive removed otherwise the GTX is already coming quite close to it/ but I noticed u can put a fan on the end of it/ that would certainly aid in my hot GTX ..... but then theres no space I dont think ! Can anyone confirm this?
The bottom cage is where I was looking to place my 3x hdds but was mortified to see theres some pointless silver frame at the front which well doesnt come out, so its like theres a space for a 120mm fan but you cant put one in? I maybe mistaken on that!
So again no active hdd cooling well not on the bottom cage at least/ so slightly higher hdd temps which aint good. even the bottom front panel has a design/style for air vent holes but there all closed and solid? I understand it can still get air from side vents but it looks like they almost made the botton front and inside for a fan/ventillation for better cooling but then decided not to at last minute of design !
Good points I felt were:
Hdd grommets, they did actually make a difference in overall noise and reduced it a good 20-30% id say.
Large rubber feet good again, and silicon strips around the p/s cage to stop vibrations so again good stuff there.
My GTX fan revs up quite badly even with a 120mm fan on the middle with no cage there its on full blowing across my GTX, however on the Antec 900 I had 2x120mm fans blowing across entire pc/graphics/ so never had this issue and cpu/mainboard system temps were nice and low as well as the hdd temps.
Overall my Antec 900 was a lot more solid and thicker plastic/way better cooling for hdd/GTX/mainboard/cpu, and just about the same size, it prooved just as silent with just 2 front fans blowing over every component
Oh and the Door.... worst design ever, I went to push it back and it has a nasty snapping into position clicky system... cos I needed to use the dvdwriter and it just snapped on top and fell off (Case is 3 days old note!)
That last bit was the cheese on the cake for me lol
Anyhow my Antec 900 was way better in terms of cooling/while not as organised with cable managment and the modular systems the case was sturdy/harder solid plastic.... a good mid size, bit cramped in comparision but it meant the front cooling could cool all parts of your pc perfectly unlike the antec 182. There both close id say Antec 900 wins, my Eclipse 62 wins on space/easy of build but it suffered from vibrations here and there and was more prone to noise leakage.
Gonna see about returning my Antec 182 obviously
but these guys making these cases should really think about the GTX and hot 500giggers and mass heatsinks cos they been around for a year as it is !
*Pukes*
