My new kitchen - nearly finished
ill let you off then :) Iv just been through the same, i wont be doing a full kitchen again in a while! Looks like you did the Jig yourself(its in one of the pics), how did that go? I didnt want to try it and ruin the work tops.
had a little help from my dad with that and its something I would suggest not to just try it on your own without some help
Sweet work... Wish i was that handy with DIY, takes me 3 hours to put a shelf up...
Garden i can do, its the inside im impressed with. What was the cost of all that work? if you dont mind me asking..
Colin
Colin
All the work or just the kitchen ?
Just the kitchen would be running at about £3500 so far including glass extractor im doing tomorrow (pics to follow)
All the work - Everything on house so far would be running to high
Wall ties , double glazing and doors , rendering = £15000ish
Extention plus furniture ect = £35000
47inch tv front room = £1800 32inch tv bedroom £800 :cool:
Fridge shy of £800 , washing machine and tumble = £800
The list can go on and on but in total so far spent about £60000 plus
Still managed to get myself a new car aswell :D
Bits and pieces here and there , but i am very handy I like to think with things like this , have had guidence from father in law and step dad
All cleaned for Gaijin
I love DIY, I do.
I will post some pics of my own, once my bedroom is complete. Im still in the process of painting it. Its been a work in progress for over a year now.
I can see that you are working on different parts of your house, so keep the pics coming.
Fair play to you, is impressive. I've had skirting boards 'resting' against the walls for over 12 months now! I can paint and hang paper but i suck at evrything else that is DIY.
Just looking at doing some work on my house and I need to remove a chimney breast, any tips or advice seeing as you've done such a good job.
Start at the top and not the bottom :rolleyes:
Seriously its a lot of work involved . scaffolding all the way up , remove chimney on the top of the house and then in the loft and work your way down brick by brick . Dont go at it with a sledge hammer or you will damage something you dont want to .
Removing a chimney breast is a lot of work. If you are living in your property while doing the work, there will be A LOT of mess and disruption. Expect builders dust to be EVERYWHERE.
You have to ask yourself if removing a chimney breast and gaining an extra few square feet of floor space is really worth it. I asked this very question to myself and decided against its removal. And besides, if you ever do decide to move, you can install a fireplace which will add value to your home.
Is there any particular reason why you would like to remove the chimney breast or is it just the extra floor space and a nice flat wall?
We would like to knock through to the dining room (I think it's the in thing tbh). But there is an old chimney breast were years ago an arga used to be.
We've had a quote and it was 4 grand but they were going to remove the ground and first floor brickwork and put a lintell in to support the stack.
Seems like a good idea to just remove the full lot brick by brick starting from the top.
If you start at the top the dust just falls down into the bottom of the breast so you only really get dust in one room at the end .
What use does a chimney stack and fireplace serve these days ? Almost everyone has central heating and if you dont use the fire place just think about all that rain water going down there .
The extra few square feet aswell make a hell of a difference in anysize room aswell .
Damn mate that is some really good DIY there, tho i do have to comment on picture 4, does anyone else see the sun?
