theres enough space
Compared to LL 2000+?? I think 8 dedicated HD slots (with direct air cooling) is the minimum when looking at "full towers"
theres enough space
Antec900 now theres a case that knows what its doing...if only it was a lot more wider/longer and support for GTX + longer cards and fan filters that would be utter perfection.
I got an 8800 ultra in my 900, got about an inch of space between it an the drive bay, just have to take off that black thing and move hdd to bottom rack.
The HDD frame at the bottom DOES come out!
a Fan can be placed on the bulkhead behind them (inbetween the HDDS and the PSU)
after removing the middle HDD cage you can place a fan onto the front of the case, excellent cooling for an 8800GTX.
i had NO problems routing cable around my P182.
if you wanted a case so big, why not splash out on a MountainMods UFO cube-case or something.
you're being unduly picky to a very good case.
You already owned it the akasa eclipse 62.
I went for the 900 over the 182 simply because it looked too cramped, the case itself is very compact inside and not very well thought out for routing cables, although the 900 has the same issues it does cool extremely well but looks like a LAN gaming case.
The 190 seems to be the better Antec case out of the lot with the looks of the 180 / 182 with good cooling but it comes at a price!
DeadMan
I do think the 182 is too cramped, compared to the Stacker. I was trying to connect a IDE connector and there isn't much space between motherboard and edge of 5.25" bays. The case needs to be around 2" deeper (also help with bottom fan being further from SATA cables)
As a side note I was wrong in my review the bottom fan intact does have vent holes "open" so air can go thru the bottom, shame theres no space for a fan behind it!
