Vista Premium 32 or 64?
10 Feb 2007
Have most of the issues with Vista64 been resolved now, or is the 32bit version still better for gaming? As I see things, the onlty real benifit of 64 is that you can make use of more than 3GB ram. Are there any other things to consider?
Well apart from that, there are no differences. Vista x64 only brings advantages over the 32-bit version.
All programs execute at full speed, the drivers are as abundant as the 32-bit ones, and it has advantages like 64-bit code support and the option for lots of RAM.
checklist for this question..
1> Do you run any 16bit applications (you'd probably know if you did, they're really old and look rubbish this is a blunt comment, but they tend to have old gui's
(if yes, get 32bit)
2>Check to see if all your hardware has Vista 64bit drivers
(my hauppage nova-t card only has 32bit)
3>Do you want to have over 3.5Gb of ram?
(if yes, get 64bit)
-edit
-not true in all cases
Okay then, let me ask this though.
(if yes, get 32bit)
Doesn't Dosbox do this?
many 16bit applications run in windows only i think..
like the 'best of entertainment games pack' that ms made for 95, and ntport95 etc
I don't see how, I mean wasn't Windows 95 a 32-bit operating system?
Whenever you ran 16-bit code it would use the DOS emulator (which emulated a 16-bit system).
Or am I totally wrong? :)
A lot of the old setup programs use 16 bit installers which was fully supported by Windows 95/98 but isn't by Vista. And no, it's not using a DOS emulator as such, but the 16 bit Windows subsystem.
Burnsy
