Thermalright Ultra-120 temps
Probably about right.
What are you using to load the cores and what are you using to check temps?
My q6600 (revision B3 so hot :() @ 3ghz runs at 40c idle and close to 70c fully loaded in orthos.
That's under the extreme with 2x sharkoon silent eagle 1000rpm's fitted.
gt
Cheers! Is Coretemp the most reliable program for reading temps? I was a little worried i wasn't getting the full potential from my Ultra-120 as the base seemed a little convex when fitting.
They do tend to be - you could try lapping but may only get a 2-3c drop.
Download TAT as that's widely regarded as the best c2d temp reader.
It also has a handy stress loading option. Seems to push temps a little higher than orthos too.
gt
