Ati gfx cards
27 May 2004
UK
I recently bought an OC Ati X1950 512MB Pro, which at around £70, I thought, was a very reasonable deal. It also seems to be very well regarded around these parts.
But what about the other gfx cards in the current Ati range. Obviously the HD2900 is king. But what about the HD2400 & the HD2600 cards? How do these shape up against the X1950?
The HD2400 range are very cheap (£30-£46 on OCUK) & you can get some very good prices on the HD2600 cards as well (£52-93). But then the HD2800 cards jump up quite a bit in price (£162-£317).
All of the HD2600 and HD2400 cards are weaker than the X1950 Pro, with the possible exception of the HD2600X2 Gemini.
Edit: The HD2400/2600 cards all support DirectX 10, but they're so weak it'd be a slideshow, or you'd have all the settings turned down anyway so what's the point?
The 2600 does support Dx10, however it's slower than the 8600GTS from nVidia (which is also Dx10) which in turn is slower than the X1950 Pro.
I'd take the X1950 Pro personally. Dx9 to Dx10 isn't a big visual difference, and none of the cards below the 8800/2900 ranges are really quick enough to plow through Dx10 games anyway. :)
So in terms of price & performance it sounds like I made the right choice with the X1950 Pro. From what you guys have said I can certainly now see why it's so well regarded. When the NVIDIA 8800/ATi 2900 cards come down closer to the price of the X1950 I'll take another look ;)
yes the 1950 was a good choice since its launch last yeat it has been king of the budget card by a long chalk the performance for pice is huge. and as said above the only opnes on ati side faster are the top of *** range ones wich cost a lot more. i believe t hey have stopped making the 1950pro now but it will continue to be supported in the drivers.
I believe they have stopped making the 1950pro now.
That's a shame. I wonder what will replace the X1950 Pro as the top performing budget card when supplies of the chip dry up? Obviously it won't be a cheaper HD2900 or NVIDIA 8800 because, as discussed above, these are for the chop as well before long!
Well a 8800 GT 256Mb should come in at around £90-£100 so I guess that will be the closest replacement.
And it ought to be faster than a 1950 pro as well.
What about the 256MB of RAM? The X1950 Pro I have has 512MB. How much difference will that make?
I noticed the price difference between an OC 256MB X1950 Pro & one with 512Mb is only about 8 quid.
From all I've read the extra memory really doesn't make any difference at all in real life.
Interesting. I remember when Doom 3 came out (all those years ago now) a 512MB card was said to be required to run the game at max texture settings. At that time there were no 512MB cards! But I guess things have moved on some way since then & the actual graphics processor takes care of most of the hard work. So, do we really need 512MB gfx cards?
