Hi there
I forgot to mention this last week but OcUK is the first with CAS4 4GB Kits in 2x2GB form. This is excellent for the more performance orientated user who wants 4GB but does not wish to sacrifice latency timings.
OCZ 4GB (2 x 2GB) PC2-6400C4 800MHz Reaper HPC Enhanced Bandwidth Edition Dual Channel DDR2 (OCZ2RPR800C44GK)
The Reaper HPC is an innovative patent-pending cooling solution developed by OCZ to effectively minimize heat produced by high-speed memory. As heat rises into the thermo-conductive copper heat pipe conduit, it is dissipated through the strategically-placed compact aluminum fin array. By guiding performance-robbing heat away from key memory components, the unique Reaper HPC design helps facilitate improved overclocking performance, while improving longevity and stability of the modules. This high-density 4GB kit is ideal for running any enthusiast or profession system at maximum performance. At 800MHz, the 4GB Edition runs at 5-5-5 latency timings and offers unprecedented stability on the latest AMD and Intel platforms. As a Vista up-grader, the PC2-6400 4GB dual channel kit will provide maximum memory bandwidth and deliver the best possible gaming and productivity on Vista systems. As part of OCZ’s line-up of premium memory, PC2-6400 modules are backed by a Lifetime Warranty and industry-leading technical support.
* The Reaper HPC series uses heat pipe technology to rapidly remove heat from the main body of the memory modules and conduct the thermal load to the extended radiator fin array. The addition of the extended fin array nearly doubles the total surface area available for heat dissipation while the heat pipes warrant near isothermicity throughout the entire design. The result is a doubling in effective heat dissipation at equal delta t or, in real systems, a significantly lower operating temperature of the memory modules.
**OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.2V without invalidating their OCZ Lifetime Warranty.
- 800MHz DDR2
- CL 4-4-4-15 (CAS-TRCD-TRP-TRAS)
- Patent-pending Reaper HPC Heatsink
- OCZ Lifetime Warranty
- 2.1 Volts
- 240 Pin DIMM
- OCZ Enhanced Latency Technology
- 2.2V EVP**
Price: £139.99+VAT (£164.49 inc VAT)
BUY NOW!!
I don't think I need to tell anyone how good a price this is for such a high-end kit, an absolute bargain
- 800MHz DDR2
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
BUY NOW!!
