Hmm seriously thinking of flogging the 2900XT for one of these, or the new HD3000 series... Is it worth it before it's too late?
The p35's and x38's will work with pci-e 2.0 cards. they also support 45nm cpu's, so buy 1 of those.
I've seen a few of these posters going up at the NVIDIA HQ ...
I don't follow why should I buy 1 just because P35/X38 mobo support PCI-E 2.0? or are you saying I should get the mobo?
But ill check anyway to make sure,
You've splilled some beans already so another little titbit won't hurt?![]()
I got your drift anyway thanks clockaBut ill check anyway to make sure,
http://www.overclockers.co.uk/showproduct.php?prodid=MB-086-GI&groupid=701&catid=5&subcat=913
This was what i was about to buy, along with a q6600. Still unsure as to what ram would be my best option, to go with the board cpu and the gt when it arrives. Tips are welcomed![]()
go for some 2gb crucial ballistix ddr2 667
667 to keep the cost down? or would i be better with 800? Thanks for your help and sorry for the hijack![]()
the 667 overclocks to 900+. so you could run something like 450*8 = 3.6ghz
In response to LoadsaMoney:
No, i'm waiting. Just don't know if i'm waiting for something i won't be able to use! Can't seem to get any answers as to whether it will work on an Asus P5NSLI mobo?
