selecting HTML pages from drop down menu
31 Oct 2005
Leeds
pretty simple query, I'm a noob web site maker
I need a drop down menu on a page, that when you choose an option from the drop down menu, the page changes to that page
I.e menu
Index
Contact Us
Shop
and it will take you to the relevent page
nothing fancy, very basic
Cheers for any attempts
Here you go:-
Code:
<html>
<body>
<select onchange="location.href=this.options[this.selectedIndex].value;">
              <option selected>Quick Links</option>
              <option value="http://www.mysite.com/index.html">Index</option>
              <option value="http://www.mysite.com/contact.html">Contact Us</option>
              <option value="http://www.mysite.com/shop.html">Shop</option>
             </select>
</body>
</html>
Give you this
http://www.bournetechnology.co.uk/test.html
Obviously you need to chage the values there 'mysite.com' and the page names to suit your needs.
Enjoy
cheers for help
only problem is when I select something from the drop down menu nothing happens??
I've filled out the website paths in the code, do I need a submit button or something?:confused:
All that does it remove the need for a submit button. You could have the original one but as you say you'd need a some sort of action button which smells.
Hope it goes ok
Please bear in mind that the onchange event handler has accessibility issues -particularly for keyboard only users. IE will trigger the onchange event if the user tries to cycle through the select options with the up / down arrows before they have had a chance to see the options. A small "go" button alongside isn't a big price to pay to make your site friendlier.
For more info: http://www.google.co.uk/search?q=onchange+accessibility
This is very true, but who the hell uses a keyboard to navigate a website these days! :p
