This is an email I have just recieved from 'point of view' regarding the PCIe 2.0 issue.
Dear sir
The new upcoming cards are all downwardscompatible.
With kind regards
Point of View / Technical Department
Albert Offerein
Dear sir
With kind regards
Albert Offerein
Why are you going around randomly posting this on multiple threads? This tells us nothing we didn't know. The issue is this: some boards are PCI-E 1.0, some are PCI-E 1.1 - the latter will be compatible with PCI-E 2.0 boards, the former will not necessarily. The issue is people finding out which boards are 1.1 and which are 1.0.
What makes you think that PCI-E 1.0 boards aren't compatible with PCI-E 2.0 gfx cards?<snip>
I was confused at your attitude to redline.. he was posting more information about all the PCI-E motherboards being compatible.
If it was the case that POV thought PCI-E v1 were not compatible then would have replied to redline that there may be some compatibility issues with v1.
Thank you, and just to clarify I asked whether they are compatible with both 1.0 and 1.1.
Which reassures me as I have a 1.0.
A 3.8GHz Q6600 is an absolute beast, let alone 4GHz. What cooling are you running easyrider, and what was your previous highest Q6600 clock with the P35 chipset?
Also I'm surprised that you managed to go from an Abit IP35 Pro to an X38 Gigabyte for only £30 - details?
Anyone think it's rather 'convenient' that the Crysis single player demo is turning up this weekend. Just enough time for people to decide they need a new graphics card...
Expect to see at the start of the demo "sponsored by Nvidia"![]()
