I think i'm gunna.
22 Oct 2006
Join the Mac owners club,
Keep keeep tempting get a Macbook, just the standard 2ghz, 1gb ram,
And upgrading the memory from OCUK.
Also getting it under the Eduction Institute Staff section :)
I will be getting it with lepard and running XP on bootcamp on it :)
Anyone tip me over the edge to clicking order?
DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT
Enough for you ? :D
Just. Click. The. Damn. Order. Button.
It will make you warm and fuzzy inside, after the few days of wondering what the hell you've done. ;)
I'm gunna do it tomorrow i think, just gunna check the cash tonight then buy buy buy :)
Bring on leopard :)
Time to order another FoofCase now for myself :)
OOOOooo Free Ipod Nano too :D
Cmon, DO EEET!
If you don't need XP then don't bother running it on Bootcamp.
You will see what I mean once you use OS X for a week or two :)
LOL @ Arnie.
With screen brightness at 50% (more than enough), wifi on, normal usage (CPU < 50% load) I'd say about 4 hours in my experience.
That wasnt a bad guess actually, my MacBook (2Ghz, 2GB RAM) is on 94% charge and the time left is reading as 4 hours 37 minutes.
The timer tends to overestimate slightly.
