Possibly a silly question
13 Oct 2006
Surrey
Can i plug more than one router in at once and have them configured etc on the same phone line? The walls in out house are too thick for wireless and i was wondering if i could plug a router in downstairs and upstairs?
Cheers
I think Billy's got the wrong end of the stick - you can't connect two routers to the one ADSL connection.
Billy's right in that you could connect one router to the other by their LAN ports (or LAN on one to the WAN on the other, if the other router would take its connection to the outside world over ethernet). You'd have to use wireless or some kind of cable to connect them (whether it was HomePlug using your electrical wiring or cat5/6 doesn't matter).
You can't connect them both directly to the phone line though.
