Spybot - Search & Destroy 1.5
7 Mar 2005
LU7
Has anyone else who has Spybot SD 1.5 realised that it takes ages to load up? I find whenever I run Spybot I can be waiting up to 30 seconds or more waiting for it to load. This is about 30 seconds until the progress bar appears and then Spybot.
Or is it my PC? :o
What would your pc case have to do with Spybot :S
kekeke! :-p
:D Kekeke
Just reinstalled. When I run it after the install it loads instantly. Running it from the desktop and I'm still waiting 30 seconds.
I had no probs with the 1.4 release, its the 1.5 release causing me problems.
Or is it my PC? :o
Its a bug go to there website and download the fix which is a new exe file
http://forums.spybot.info/project.php?issueid=85
Download link is in the first post hope this helps :-)
Lol, didn't read the whole thread ;)
Uh, it's totally borked the installation.
U need to copy and paste the 2 new files over the original files in the spybot folder.
so C:\Program Files\Spybot - Search & Destroy copy the spybot exe into this folder and then copy the domains file into here C:\Program Files\Spybot - Search & Destroy\Includes
