I had to replace my air con rad as it had over 6 holes in it, so instead of forking out £200 for a new one I bought a one from a scrap car for £20 inc delivery.
When I took the old one out I discovered that one of the pipes connecting to the rad (metal) had snapped off, so I needed a new one of those as well (£50).
The guy that sold me the scrap rad left this pipe on for me, for no extra cash, but for some reason bent it back over the radiator so it would fit in a shipping box, instead of just removing it with an allen key.
I have bent the pipe back to the correct shape, but obviously its now got stress lines along the bend point, as it is quite brittle metal and was never meant to be bent like that.
It doesn't appear to be leaking (using an unscientific blow test), but I am worried about gassing up the system if it is just going to leak out because of stress fractures in the pipe.
Is there anything I could put over these stress lines to stop it from leaking (would epoxy work?)?
