Go-Karting tips
18 Oct 2002
Going indoor go karting in a few days, and i have been before. I know how to take racing lines, to brake in straight lines, etc etc. Just wondered if you guys had any awesome little tips or tricks because i want to destroy my friends :D
Lose weight.
If you are significantly lighter than your mates, you wont have to know or do anything else to whoop them.
This is also the reason why scrawny 16yo little ****s can get well out of shape into every corner/take bad lines/whatever and STILL set faster laptimes than you.
Don't try to get through gaps that don't exist
Corner sensibly otherwise you'll just loose traction on every corner.
Just remember, the rear of the kart is wider than the front, and i've made that mistakes so many times.
Only by a couple of cm and if you were hitting things with the back end of your kart many times then you've got issues!
Keep your left foot well clear of the brake pedal, or they'll overheat and fade right when you need them. Even the slightest pressure can cause them to engage slightly.
I used to go karting a lot, when you're pressing for every extra little bit, it's quite easy to clip a barrier slightly :p
Yes good tip either use one or the other. Obviously do not use both engine backfires to hell :D
I too used to go karting an awful lot, but I didn't make a habit of losing time by hitting things :p
Does make a difference, but really depends upon the type of karts they are as some are wider than others.
When it's indoor, it's usually a lot tighter and more difficult to overtake, so watch out for people making mistakes and take advantage of it.
Also, if the surface is quite slippy (usually the case for a lot of indoor places), poorer drivers will end up sliding their back end a little, if you ease off and make sure you're not sliding too much, you should get a lot more speed, though it will depend on the corners and karts, as sliding can often be advantageous on some circuits.
I really want to go karting now.. :(
I'm probably far too heavy to be anywhere near as quick as I used to be :/
Bloody hell, haven't seen you around for a long time dave, how's it going?
Probably lighter than me :p
I was pretty chuffed with myself the other week, first uni karting club event of the year as my times were rather good even though I've got a 15kg handicap over most of the members :p I've got a lot better over the summer :)
I'm no bigger than I used to be, that's the bizarre thing! No muscle to show for it, i'm not any larger.. dunno where the hell it all is :/
I reckon we should have a ocuk go kart meet at the go kart place round the corner from ocuk, dont know if its any good or not though.
There needs to be an OcUK karting event sometime, as they always seem to fall on their arse every time somebody tries to get one sorted.
If the kart is any good then turn harder then you think it can handle. Most will take corners a lot faster then what most people realise. It's just a case of a clean line, smooth turn in and balancing the power to keep it in shape. I love karting, set a lot good laps at tracks.
When I went karting, it was pretty hard....because of the way you sat, you couldn't twist your foot and rest it anywhere other than the pedal. So you had to either rest the foot lightly on the pedal, causing some fade, or tense your ankle to keep the foot well clear of the pedal. Which ended up being pretty painful after a few hours.
Still, karting is great fun. 60mph 4 inches off the ground is a huge rush :D
