Coasting?
( |-| |2 ][ $;10369219 said:
So you're the one who sit's in traffic queues and at traffic lights on their brake lights! Blinding me and giving me head ache. I've a good mind to go at people with a stick sometimes.
Use the handbrake in stationary traffic like you're mean't too. Automatic drivers are the worst because they can't be bothered to shift to P.
PS obviously I understand if you're at the back of the queue that's different, but once you're no longer at the back you should get off the brake.
Huh did you miss "depending on the situation"? I rarely have to do it. But if I can see some Nova tearing it up behind me then I might decide to display the brake lights just to so that I know I've done everything in my power to prevent an accident.
PS: This is an IAM technique so you're slating them as well ;)
Must be bad traffic if you sit there for a couple of weeks resulting in the disc and pad binding.
Can warp disks and shorten the life of pads due to heat not being allowed to escape (even if they are drilled/vented). Thought this was well known but obviously not.
:D
Usually because their gear selection went wrong and didn't react in time for the corner - i.e. they shouldn't have passed their test in the first place.
So you've never done this then?If not i dont believe you and if you have then by your own admission you shouldnt have a license?
Nope? It's one thing making a bad gear selection and then getting it right but completely another to get it wrong and then just think "**** it, I'll coast it instead"
What the "my own admission" thing all about ? :confused:
:D
Which takes several hours to happen and would have needed either a very very spirited drive before hand or a track day to get them that hot.
I haven't passed yet, test in few weeks.
But my instructer tells me, if im going round a slow corner then use the bite and controll the speed with the clutch. Then as you straighten up ease the clutch up into the gas.
Well thats how i do it anyway, wouldn't feel in controll with the clutch all the way down :eek:
0_o
No wonder people say once you've passed your test you can "learn to drive properly"! ;)
If you're about to go ruond a "slow" corner, slow down, select the appropriate gear for the bend, depending on your speed, release the clutch and drive round the bend. You can control the speed with your brakes, the car won't stall in 2nd gear until you get to about 4mph
0_o
Dont know ! I was also told the instructer teaches you how to pass the test, after that you learn to drive :p
Most corners i do what you said above, but in places im not sure of i sometimes slow down select 2nd but dont release clutch fully, take the car round on the bite, controlling the speed with the clutch.
I guess its confidence :p
0_o
I don't see the problem with it - I was taught the same thing. The car isn't going to unbalance itself at this sort of speed and if you did need to emergency stop then the clutch is already depressed. It's just a different way of doing things, it's not wrong.
Im bad at coasting coming up to traffic lights but that is about it, some corners in local residential streets.
Its bad just don't do it ;)
What's this going round corners slowly people are speaking of? :D
pussys... all corners should be taken with a little bit of handbrake.:p
Also, when sitting at traffic lights with the clutch lightly biting, it isn't going to do that much damage surely? Sure it may wear your clutch down from the 100k miles you may have got from it, to 95k, but other than that, its hardly that bad?
