Comp just died..emergancy upgrade
26 Dec 2006
Oxon.
Hiya guys,after battleing with my comp 4 quiet a while now.my comp finerly gave up life. I was just wondring if u could give me a quick spec 4 new parts. Iave got about 600ish to sPend.
put it this way,iam on my fone sending this msg.0
i do have hds,snd card,case.howevr my memory is ddr1.my gfx card is a 7600gt which i gues could b used tempoury if a new gfx card is goimg to b relesed soon.0
0
i appolise 4 th lng msg,and if it reads crap.. Thanks.
Hiya guys, after battling with my comp for quite a while now, my comp has given up. I was just wondering if you could give me a quick spec for some new parts. Budget is £600.
I have; HDD's, Sound Card, Case. The Memory i have is DDR1, the Graphics if a 7600GT, which could be used temporarily, as a new graphics card (8800GT) comes out soon.
Thought id clean the post up.
Right this what I thought would make you happy again -
Used the 2900 as a price guide for the new 8800GT so when monday comes just change the 2900 to a 8800GT. And if the Card will cost more, then just change the motherboard to a http://www.overclockers.co.uk/showproduct.php?prodid=MB-243-AS&groupid=701&catid=5&subcat=913 .
hey guys. my psu is a 380 targon which is getting on now, i will be upgrading that to the 520 corsier. my case is the lian pc7+ which is fine. OS / keyboard not needed.
that spec u did me there, i would say does me nicely. i think i will buy those bits 2moz, excluding the gfx card, i will jsut just use my old 7600gt till that comes out. tbh though, i cant really wait for that to come out before i buy. i need my comp you see.
cheers.
That cpu needs a heatsink.
I would go for
2 lots of GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
£63.98
(£75.18)
Arctic Silver 5 Thermal Compound (3.5g)
£5.99
(£7.04)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK)
£57.99
(£68.14)
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - OEM
£135.99
(£159.79)
Gigabyte GA_P35C_DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard £64.99
(£76.36)
Tuniq Tower 120 CPU Cooler (Socket 478/754/939/940/AM2/LGA775
£27.99
(£32.89)
And an 8800GT - £150.
Comes to £580 inc.vat & delivery
