Drop a 8800 GT in it and you'll be away
True true...Have to see how expensive they are
But currently I'm amazed at how well the x1900xtx is holding out with current games. Especialy for how long ago I brought it now!
Another "Dx10 on XP" thread eh? Thought we were due one of these.
It is now pretty much a figure of speech, no one actually believes we are using DX10
Is it our fault we are using on XP (with better performance) what the developers call DX10 only graphics?
You're completely missing the point, which is that Crytek told us that we NEED Vista to play crysis with full eye candy, which is obviously untrue.Another "Dx10 on XP" thread eh? Thought we were due one of these.
 I had the same spec rig as you (since sold my Opty 185) so it will be interesting to see what you get. (might then re purchase a cheap 939 dual core
 I had the same spec rig as you (since sold my Opty 185) so it will be interesting to see what you get. (might then re purchase a cheap 939 dual core  )
)You're completely missing the point, which is that Crytek told us that we NEED Vista to play crysis with full eye candy, which is obviously untrue.
The game looks way better with the bump mapping, soft shadows, sun rays, etc enabled, and ALL these features work fine in XP with little loss in performance.
 Although my FPS did go down from the 30s to 20s.
Apparently, the calculations for these effects are farmed out to the CPU (in DX9), so they don't add much strain on the GFX card, unlike post processing and shaders which are processed mainly by the GPU.How can they work with little loss if they are the real thing, turning either post processing or shaders down gives a 10FPS boost in each in DX10, so turning them both up you can loose 20FPS
Here's a comparison of XP vs Vista from the original link:i'd like to see some screens comparing vista dx10 very high against xp dx9 very high. If theres no diffirence then what a con
Silicon Chip said:Hi, I'm back with new pictures comparing the DX 10 Very High to DX 9 Very High.
DX 10
http://www.uploadgeek.com/uploads456/1/Vista DX 10 Very High.JPG
DX 9
http://www.uploadgeek.com/uploads456/1/XP DX 9 Very High.JPG
 It's about marketting Vista, just like you can read quotes from Crytek about how the game absolutely needs quad core and will be CPU bound for most people, which turns out to be total BS since as it happens the game uses little CPU power and a decent dual-core is plenty enough for it.
