but still, if it got him to work then wouldnt start, that seems a bit off, more likely to be an electrical issue is my gut feeling.
as for temps going crazy... sounds like its looked after well lol
How about the engine management light on the dash is that on at all?
Should look like this:
http://www.theaa.com/motoring_advice/Images/eng_man_light_72.jpg
with the new info about the cooling, you almost certainly have stupidly low levels of coolent, if you have a leak, then it wont necessaryly, replace liquid for the overflow bottle.
it won't be battery, by over heating it you could have knackered any number of things.
fuel pump is a good start, but before anything, top your rad up.
p.s. further to the coolant temp sensor idea, the car's temp gauge has been going crazy upto 100c when idling in any kind of traffic for more than a minute then the fan in the engine bay goes mental to reduce the temp back to normal as much as it can, im assuming that cant be good then? ive not had chance to book it into a garage or anything since that started as im working 9-6 every day
Fuel, Compression, Spark
Take your pick![]()
why was this sound advice ignored? They'd be first three things to check, and by fuel - not fuel in the tank, fuel in the cylinders where it needs to be!
I don't know your engine at all, but if it were my car doing that then i'd be looking at the TDC sensor.
and at the time he was at work, if it had been me i wouldnt have had the tools to get my plugs out, let alone test for a spark.
