Don
- 20 Oct 2002
- In a house
Finally got around to replacing my front brakes today, will do the rears in a few hundred miles when the fronts are all bedded in!
Thought i would document the process for you lot, im sure this is like trying to teach most of you what you already know, but someone might like to see how its done.
(Bear with me, this will take a long time, so posts will appear with just pictures at first!)
Here are all the bits required...
This is where i am doing it...
Loosen the wheel nuts before jacking the car up...
Next i chock all the wheels with bricks and then raise the car to working height...
Once the wheel is off, and I set about loosening the allen bolt that holds the disc in situ, it should not be tightened much at all. (Excuse the blur! All photos are taken on my phone!)
I had a look at whipping off the whole caliper and mount in one go, but it was too busy back there, so i gave up on this part, and decided to remove the caliper first.
This is where i had my first problem! In attempting to remove the caliper, I nearly brained myself whilst snapping my "lifetime guarentee" halfords "professional" hex kit!
So i ran off the local motor factors and grabbed a Laser set..
Haha!! Success, Laser for the win!
Quickly whipped off the spring which i had forgotten to do!
