yer but them engines are crap
1.4 tdci/hdi - 150k
1.8 tdci (ford not PSA)- 100k
rest of psa - dont know, dont care.
vag makes the best diesel engine
er why are they 'crap'?
HDIs are not 150k... no idea where you got that from.![]()
The 1.4 8 valve psa engine is 150,000 miles ive just double checked on autodata
PSA is crap, Ive driven EVERY psa hdi upto 2.2 and wasnt impressed.
thats the same engine in the saxo. i very much doubt its 150k. i cba to check tho
and the HDI engines are very solid lumps. if you werent impressed, what were you expecting? its a diesel at the end of the day and a very good one at that.
no saxo was ever fitted with a hdi engine. it had a 1.4 petrol and some old 1.5 diesels
i own a diesel my self (well getting rid this week) and its much nicer then the hdi's ive driven, even though mine (1.8 tdci) is regarded as a poor, unrelaible engine on ffoc.
They also go like **** off a shovel, our 130 is not only quick for the type of car it is it gives around 54miles to the gallon.
The reason that VW expects cambelts to be changed at 60k intervals is that PD engines generate a lot of torque in a "peaky" fashion - hence the need for dual mass flywheels to soak up the momentary excesses.
Interesting point, do other manufacturers use a dual mass flywheel?
[TW]Fox;10381566 said:Good to see the term 'character' is still being used as a better sounding subsitute for 'flaws'![]()
[TW]Fox;10381762 said:The power delivery is lumpy, they sound like old school diesel engines and require the sort of servicing regeimes you'd expect from a hgher end petrol BMW or Audi.
This, in a VW Golf, is a flaw, not character.
