- 13 Jul 2004
- Stanley Hotel, Colorado
I like the green and how its patched. Will you just spray it all one colour in the end
How strange, I've had exactly the same problem with my car (MG ZS with a k series engine). I get plumes of smoke, I've replaced the head gasket, head, checked compression and checked all breathers etc. I resigned myself to the fact something strange is going on in the bottom end so got a reconditioned unit. It started happening after I changed the oil, gradually getting worse and worse until in the end it was like a fog behind (worse when car is cold). I didn't overfill it and even drained all the oil again and measured exactly the amount I put in in case the dipstick was dodgy and it wasn't.Problem is primer is porus and the metal will rust under, thats the nightmare im going through at the moment. With the cold weather setting in here the car needs painted asap, but unfortunatly the engine is giving me soo much gip i've given up and the car will be collected soon by the triumph specialist to have the engine looked at.
I have constant smoke coming out the exhausts, which would suggest a head gasket althouth that has just been replaced, the compression on all cylinders is good, it aint using water, aint using oil but still plooms of smoke on acceleration which seem to have every colour possible. Replaced the inlet manifold after not having much vacum, replaced the carb jets, replaced all gaskets. timing is perfect, drained the fuel replaced it, drained the oil replaced it. Its got a brand new skimmed head with new valves and guides.
So im stumped, at the moment its either looking like piston rings, or poor valve guides or another head gasket.
How you getting on with that Jawel paint? Celly or 2-pack? I had some 2-pack from them and it was crap![]()
I've got some 2 pack from them too - what's up with yours? Mine seems a bit runny but I've not done much spraying before.
2 pack is quite runny. Mine never cured off properly but I'm thinking I must have had a duff batch or not mixed it up properly.I've got some 2 pack from them too - what's up with yours? Mine seems a bit runny but I've not done much spraying before.
