AARRGH! How do I get rid of the Creative Audigy splash screen at bootup...
15 Nov 2003
Marlow
If I run "Creative Splash Screen" from programs I get a program on my task bar, but can't do anything with it.
I've even tried nukin the program from my registry, but it keeps coming back! :confused:
if u go to Run and type MSConfig, you can control startup items and services, just disable the creative audigy startup item
Nothing stands out as being the obvious thing to omit?
You've got things like:-
SBDrDet /r
CTSysVol
CTDVDDet
If the splash screen annoys you that much uninstall the driver and software then do a custom install from the cd only installing the apps you need.
I did... Maybe the splash option went in under my radar when I did that!?
