Also, remember SLi doesn't work in Crysis yet, so those people with uber SLi setups arn't going to be getting any better numbers than us folks with single cards.
http://aten-hosted.com/images/crysisSLI.jpg
Crysis has supported SLI for awhile - with an average +80% framerate boost - its just most people are too thick to work out how to get SLI working/working properly - hence most of the negative comments about it - mostly due to user incompetence rather than any lacking ability of SLI.
I agree here Rroff!Heh bit of a rant coz I just got done with some guy in IRC who claimed that SLI never gave more than 20% boost - maybe 30% at best and that he'd tried ever SLI solution going...
nHancer is a good start so you can tweak the profiles manually and ensure that whatever exe name is being used is added to the profile - especially with beta and demos they don't often have the same .exe filename as the retail product - which is the one in the SLI profile.
You might be surprised when you check the FPS. It often 'feels' like 35+ fps when it's actually in the mid 20s.i get EXCELLENT fps with the dx10 hacks on xp with:
2 x 8800GT's @ stock
Q6600 @ stock
2gb @ 850mhz
i never check it on the fps counter, but i know it has to be over 35 fps 80% of the time.
ill get some exact figures if you guys want?
Q6600 @ stock
2gb @ 850mhz
1680x1050x32
It shouldn't be necessary to adjust a single thing for SLI, that's bad bad design then.
