Q6600 Upgrade
26 Nov 2005
Doon the Bay (Newcastle)
So its been two years (almost) since my last upgrade and the Crysis demo sort of confirmed that its time for another! :mad: :D
It was always on the cards, and i've been looking round the MM to get some decent deals, only nothing has really come up that i wanted to take the plunge for, so i think i will buy new.
I've currently got a 3700 SD 939, Epox mobo & 2GB GeiL DDR1 Dual-C. Its served me well, but now is the time to be looking at an upgrade for sure. The following being what i'm thinking of going for:
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W
Gigabyte GA_P35_DS3R (Socket 775) PCI-Express DDR2
Corsair 2GB DDR2 XMS2 DHX PC2-6400C4DHX TwinX
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
£320 delivered.
I will be using my 7800GT till after xmas with the new build. Can't afford it all right now, and thought this would be better to upgrade 1st rather than getting a new GFX card.
Anyone got any suggestions for anything that could be changed before this gets ordered?
Cheers
I have recently upgraded to the same motherboard, RAM and processor as you, and have had no problems with them at all. They all seem pretty quiet, and although I used a Zalman 9700 to cool it, the Arctic cooler is reportadly still very good at cooling quad cores.
Out of interest, what is your PSU?
Snip
£320 delivered.
Cheers
Very good choice, if you have a 530w-630w psu should see you fine
two options i would say would suit your needs and budget though your ability to play crysis won't be improved until you get a new graphics card.
or
Right, so a new PSU is basically essential.
Well since i'm not going to be overclocking the computer at all, i suppose i could go stock for the fan, and go for the GeiL memory and incorporate a PSU in my budget.
the stock fan is rubbish! i would suggest buying the fan on offer this week i posted above as the stock fan is like an ant blowing on a lava field.
and the geil is just as overclockable and i am sure people on here will help you do that with ease :)
nope but the huntkey ocuk one is from what i have seen the best watt per £ :)
and if you are planing on uprading that GFX card to a 8800 series you are going to need atleast 500 if not 550 watts :)
Yeah i will have to at some stage go for the 8800GT, so i guess i'm just going to have to bite the bullet on this one.
While i've got you i'm currently debating this:
http://forums.overclockers.co.uk/showthread.php?t=17798745
OcUK 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit for £60 instead of going for branded 6400, what do you think?
You don't get a stock cooler with the OEM Q6600's.
Aye i know, if the stock cooler was decent enough i'd have gone for the retail.
But i wont be overclocking anything, so i cant see why it would be able to do the job it was built and supplied to do, even as a temp measure.
i have 4gb i.e. 4 x 1gb sticks of the pc8500 ocuk branded ram running and it is great! :D best ram i have ever bought but i haven't tried overclocking it yet so don't know what it is like :)
This is the most tempting now, if i have to go for a PSU, just need to mull it over for a day or so (i'm no good at impulse buying)
I've just got that GeIL ram, excellent value. Solid at default timings and clocking well, if you decide to go that way in the future.The Q6600 is a fantastic chip also.
I'm currently running:
GeIL 2GB (2x1GB) PC3200 Value Dual Channel Kit CAS3
So i'm very pleased with GeiL and have no problem using them again.
Crazy how i'll probably get around £40 for those lads considering that's what i'm paying for the DDR2 version new.
