- 26 Aug 2004
Does 169.04 give slightly better performance, also does overclocking in rivatuner work with this driver version?
Thanks
Thanks
Thanks
Do a search...
To be fair the threads are a bit massive now. You need Rivatuner 2.06 m8 & it'll work with all 169.xx driver
Si
Si
Thank you for giving me a straightforward answer, unlike easyrider's reply.
Cheers.
The time it took for you to post would have given a plethora of results.
Apologies for being frank.
It's would "have" by the way.
.It's actually "would have" by the way. You put the apostrophes in the wrong place.
To be fair. Easy did answer your questions although a little unwelcoming.
No, it's would "have". I put quotes around the word I wanted to emphasize. Apostrophes can be used emphatically.
I got A*A* in English Language/English literature so I should know... No offence...
.None taken as it could have easily been a mistake. I can't judge on what word you were wanting to emphasize lol, so the "so I should know" remark is a bit obvious as only you would know what word you were wanting emphasized.
