4 Nov 2007 at 14:27 #1 neocon neocon Soldato Joined 24 Aug 2006 Posts 6,259 my cpu is overclocked to 2.3ghz i installed a new version of cpuz and it says its at 2ghz? Last edited: 4 Nov 2007
4 Nov 2007 at 14:31 #2 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,519 Location Antrim town Speedstep.
4 Nov 2007 at 14:34 #3 neocon neocon Soldato OP Joined 24 Aug 2006 Posts 6,259 it keeps flasing between 1999 and 2333
4 Nov 2007 at 14:36 #4 neocon neocon Soldato OP Joined 24 Aug 2006 Posts 6,259 ok speedstep, i'll turn it off in the bios thx
4 Nov 2007 at 14:45 #5 neocon neocon Soldato OP Joined 24 Aug 2006 Posts 6,259 not sure how to turn it off cpu eist function cpu thermal monitor cpu enhanced halt also i see ddr 18v = Fail
4 Nov 2007 at 14:49 #6 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,519 Location Antrim town C1E and EIST are the Speedstep options in the DS3's BIOS. And you can ignore the DDR2 fail warning.
4 Nov 2007 at 14:52 #7 neocon neocon Soldato OP Joined 24 Aug 2006 Posts 6,259 thx i thought my cores were 38c but new speed fan suggests 48c, thats pretty high Last edited: 4 Nov 2007
4 Nov 2007 at 15:00 #8 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,519 Location Antrim town I would use CoreTemp.
4 Nov 2007 at 15:25 #9 neocon neocon Soldato OP Joined 24 Aug 2006 Posts 6,259 do you rekon its my heatsink/fan or the cpu itself thats causing the high temps?
4 Nov 2007 at 15:28 #10 RJC RJC Don Joined 29 May 2005 Posts 29,104 Location Kent What is your full load temps like and airflow in the case! Can your fan speed be increased on the HSF. Rob
4 Nov 2007 at 15:31 #11 neocon neocon Soldato OP Joined 24 Aug 2006 Posts 6,259 ive overclocked it to 2.8 the temps dont seem to be higher than when it was at 2.3 Last edited: 4 Nov 2007
4 Nov 2007 at 15:33 #12 neocon neocon Soldato OP Joined 24 Aug 2006 Posts 6,259 RJC said: What is your full load temps like and airflow in the case! Can your fan speed be increased on the HSF. Rob Click to expand... have changed my fan control to psf instead of auto, now its on full wack airflow is ok
4 Nov 2007 at 15:55 #13 neocon neocon Soldato OP Joined 24 Aug 2006 Posts 6,259 2.8 and stress does this mean its safe?
