reg edit happy, mucked up a server...help!!
5 Jun 2005
Southampton
Tried to install SQL 2005 on a windows 2000 server. It failed on install asking me to edit something in the reg. using regedt32.exe, I did this and then the whole line
([HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Perflib])
Turned to IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII ????????
To cut a long stort short, but backup notepad failed and now SQL 2005 wont get past the fist install button……
Can anything be done guys?
hmm
Try reverting to a system restore point; luckily all the things you have changed will be reset.
Next time, always make a copy of the setting or key being changed, export the key to your desktop and execute it from there if things go pear shaped. I can only recommend a system restore :/
windows 2000 no restore is there?
Do you have any sort of registry backup? The only thing I can think of is to recreate all of the keys from another 2000 Server one by one.
Looking at my 2003 box, there are 5 keys in the perfib folder which are:
Base Index (REG_DWORD) 737 (hex)
ExtCounterTestLevel (REG_DWORD) 4 (hex)
Last Counter (REG_DWORD) 27ce (hex)
Last Help (REG_DWORD) 27cf (hex)
Version (REG_DWORD) 10001 (hex)
THat might work, but maybe someone with a 2000 box could verify?
Burnsy
From my XP, if its any use:
Code:
"Base Index"=dword:00000737
"ExtCounterTestLevel"=dword:00000004
"Last Counter"=dword:0000137a
"Last Help"=dword:0000137b
"Version"=dword:00010001
cheers mate, i have found another 2k server i may be able to get the info from... i'm such a tool not taking the proper backup route, i thought i had it covered!
regedt32.exe seems to give diffirent results to normal regedit, but this maybe a 2k thing!
