Xbox 360 Video Formats
Caporegime
18 Oct 2002
Lake District
What video format's can you play off HDD's plugged into the USB socket on the 360? I want to play DVR-MS files at a friends house without needing MCE.
Any ideas?
Didn't think you could play any video files from a a portable device. Only music and videos. Could be wrong though.
When you see files labelled x264 those wont play will they?
No, it is not so much the file format, but the container it is encapsulated in that is important. The files you refer to are probably in a mkv or avi container, which the 360 won't play natively.
This is a list of exact formats and containers that are supported as of last relevant dashboad update.
http://blogs.msdn.com/xboxteam/archive/2007/05/09/spring-07-video-playback-faq.aspx
Have you got any links regarding this?
Does there need to be a particular file structure to do this? If so i could play my itunes library.
See above link, but it isn't as straight forward as you having .mov/mp4 that are in your tunes library. They have to have been encoded using a specific "video profile". I think stuff bought of ITMS won't work. It would not surprise me though if a Quicktime HD trailer of Apple's website may well work.
rp200
You just went back on yourself in the same post? Anyway ic1male is right. I can play my PSP movies on there if I wanted to :)
rp200
Can you change the container of a file without re-encoding the whole thing?
Yes you can! However the audio may need converting as the files you refer to are often encoded with 5.1 audio profiles and the 360 only supports stereo. But this is still vastly faster then re-encoding audio and video.
I can't think of any software off hand though.
rp200
I wasnt clear sorry i just meant music files. I was thinking i could copy my itunes folder onto a portable hard drive and connect via usb 2 and play away. What playlist formats does it support?
Sorry I meant pictures lol. I'm taking it the ability to play videos was included in a update then? It's just after looking on the net I'm finding out that it only played music and pictures.
