We need a new TV and have looked at a fair few this afternoon. The following TV's are what we are looking at in order of preference.
SAMSUNG LE40F86BDX £1400
SAMSUNG LE40M87BDX/XEU £900
LG 37LF66 £800
The picture on the F86 was noticibly more vivid than the other TV's there. The Samsung LE40M87BDX/XEU (£900) was next but one and all
TV's were fed with a high def blue ray feed but the F86 looked better, the colours seemed more vivid than any of the other TV's.
Is it worth the extra £500 difference from the other Samsung though? I think the noticible difference is the 100hz and the 25000:1 contrast ratio (the other samsung is 15000:1). Has anyone seen these with a SD def feed (the missus will mainly be using it for virgin media (not HD)).
The TV will be used for (in order of frequency-but HD DVD will overtake normal DVD when availabilty increases) 1. SD NTL/Virgin media, 2 SD DVD, 3 HD DVD/Blue Ray, 4 PS3, 5.PC (might not bother with PC connectivity for some time). I may also enquire about HD virgin media.
Unfortunately the LG was in the other shop so I couldn't directly compare this against these samsungs.
Any thoughts on the above, I will need an upscaling DVD player as well.
I have done a search on the forums and the F86 does seem like a fairly solid option. The prices above are from a couple of high street heavies so if I could knock a few hundred quid off I might be able to pursuade the missus (she only wants to spend max £1000, but she does like the blue light lol). Obviously don't mention competitors but please give me an idea of what it is available for.
I like the idea of being able to update the firmware via USB should you need to.
Thanks,
LG 37LF66 £800
Thanks,
